Im trying to add a mikrotik device and i have ping but i dont have snmp reachability
this is my validate.php
Component |
Version |
LibreNMS |
1.60-48-g6a897b5 |
DB Schema |
2020_02_10_223323_create_alert_location_map_table (159) |
PHP |
7.4.2 |
MySQL |
5.5.64-MariaDB |
RRDTool |
1.4.8 |
SNMP |
NET-SNMP 5.7.2 |
[OK] Composer Version: 1.9.3
an this is the snmp config on the mikrotik device
If you have ping but no snmp, that means the mikrotik is filtering it at some place.
Also, there was an old bug where mikrotik replied from different IP than the polled one, so snmp were not working properly.
That being said, I have a few mikrotik devices that stopped replying snmp from one day to other and I was unable to find/fix the problem. Shame on mikrotik
ty for the responce im trying to get this to work, snmpwalks to that mikrotik device are still timing out
im going crazy
i solve the issue by adding this rule on my core mikrotik device by adding this firewall rule
but adding the same rule on my distribution mikrotik devices doesnt seems to work
nmap shows the following
maybe the rule needs some change on the other devices…
any ideas?
