Hi guys,
Please help me. I’m new in librenms I can’t create graph.thank you.
Hi guys,
That totally needs more info.
What is not working exactly?
./validate.php
Graphs usually takes 2 to 3 poll cycles (10 to 15 min w/default polling time)
If you waited more time, there are 2 possible issues:
a) Your folder permissions are not right
b) Your poller is not running
Hi
Here is my ./validate.php. I installed it last wk until now graph not working.
Component | Version |
LibreNMS | 1.49-116-ga4513e9 |
DB Schema | 2019_02_10_220000_add_dates_to_fdb (132) |
PHP | 7.2.16 |
MySQL | 5.5.60-MariaDB |
RRDTool | 1.4.8 |
SNMP | NET-SNMP 5.7.2 |
[OK] Composer Version: 1.8.4
Manually run ./poller.php -d -h hostid
and check for the RRD outputs
i try the command still no graph.
Hi
As @TheGreatDoc suggested , you should check RRD outputs in the debug data of the command below. That should help you find out what is missing in the RRD configuration.
Basically, the poller command is the one that gather the data and gives it to rrdtool.
