I have LibreNMS running inside a container and when I try to run the validate.php I get and error that I shouldn’t run it as root. But when I go to run it as non-root user, I get a FAIL error saying I need to “run this script as ‘librenms’ or root”!
How do I get this working? Thank you!
librenms:/opt/librenms# ./validate.php
Do not run validate.php as root
librenms:/opt/librenms# su librenmsadmin
/opt/librenms $ ./validate.php
LibreNMS | 23.9.1 (2023-09-30T07:59:55+02:00)
DB Schema | 2023_09_01_084057_application_new_defaults (259)
PHP | 8.1.22
Python | 3.10.13
Database | MariaDB 10.5.22-MariaDB-1:10.5.22+maria~ubu2004
RRDTool | 1.7.2
SNMP | 5.9.3
[OK] MySQl and PHP time match
[OK] Redis is functional
[FAIL] You need to run this script as 'librenms' or root
