CBQoS is not showing the stats breakdown for each element in the classmap
Ingress Policy:
Match-Any: Match access-group name bdi1001-in-17 <–this is what it shows
  • [class-default]
    Match-Any: Match any
This is what is actually is:
Class-map: class-bdi1001-in (match-any)
4846 packets, 300452 bytes
5 minute offered rate 2000 bps
Match: access-group name bdi1001-in-1
0 packets, 0 bytes
5 minute rate 0 bps
Match: access-group name bdi1001-in-2
0 packets, 0 bytes
5 minute rate 0 bps
Match: access-group name bdi1001-in-3
0 packets, 0 bytes
5 minute rate 0 bps
Match: access-group name bdi1001-in-4
0 packets, 0 bytes
5 minute rate 0 bps
Match: access-group name bdi1001-in-5
0 packets, 0 bytes
5 minute rate 0 bps
Match: access-group name bdi1001-in-6
0 packets, 0 bytes
5 minute rate 0 bps
Match: access-group name bdi1001-in-7
0 packets, 0 bytes
5 minute rate 0 bps
Match: access-group name bdi1001-in-8
0 packets, 0 bytes
5 minute rate 0 bps
Match: access-group name bdi1001-in-9
0 packets, 0 bytes
5 minute rate 0 bps
Match: access-group name bdi1001-in-10
0 packets, 0 bytes
5 minute rate 0 bps
Match: access-group name bdi1001-in-11
0 packets, 0 bytes
5 minute rate 0 bps
Match: access-group name bdi1001-in-12
0 packets, 0 bytes
5 minute rate 0 bps
Match: access-group name bdi1001-in-13
0 packets, 0 bytes
5 minute rate 0 bps
Match: access-group name bdi1001-in-14
0 packets, 0 bytes
5 minute rate 0 bps
Match: access-group name bdi1001-in-15
0 packets, 0 bytes
5 minute rate 0 bps
Match: access-group name bdi1001-in-16
0 packets, 0 bytes
5 minute rate 0 bps
Match: access-group name bdi1001-in-17
5 minute rate 2000 bps
Class-map: class-default (match-any)
  0 packets, 0 bytes
  5 minute offered rate 0000 bps, drop rate 0000 bps
  Match: any
