I have a sfp of FINISAR CORP. which has the value as below
High Alarm High Warn Low Warn Low Alarm
Temperature Threshold Threshold Threshold Threshold
Port (Celsius) (Celsius) (Celsius) (Celsius) (Celsius)
Te1/1/7 31.6 78.0 73.0 -8.0 -13.0
Te1/1/8 33.2 78.0 73.0 -8.0 -13.0
Voltage Threshold Threshold Threshold Threshold
Port (Volts) (Volts) (Volts) (Volts) (Volts)
Te1/1/7 3.28 3.70 3.60 3.00 2.90
Te1/1/8 3.34 3.70 3.60 3.00 2.90
Current Threshold Threshold Threshold Threshold
Port (milliamperes) (mA) (mA) (mA) (mA)
Te1/1/7 0.3 13.0 12.5 5.0 4.0
Te1/1/8 8.9 13.0 12.5 5.0 4.0
Optical High Alarm High Warn Low Warn Low Alarm
Transmit Power Threshold Threshold Threshold Threshold
Port (dBm) (dBm) (dBm) (dBm) (dBm)
Te1/1/7 -40.0 0.0 -1.0 -5.0 -6.0
Te1/1/8 -2.5 0.0 -1.0 -5.0 -6.0
Receive Power Threshold Threshold Threshold Threshold
Te1/1/7 -3.5 0.0 -1.0 -18.0 -20.0
Te1/1/8 -3.0 0.0 -1.0 -18.0 -20.0
and i want to set value in such a way that it can flagged me red alert in the current section of below output as per above value.
