Hi All
How can you check with which MIB your devices was discovered/monitored and how can you change to another MIB?
Been looking at the detail I get out of a Ubiquiti radio vs the details from a Cambium and it seems very limited in the latter. I’m assuming it must be MIB related so would like to try a later release to see if it makes a difference.
Thanks,
R
