Hi. I’m trying to understand what the dmi and rpm scripts in /opt/librenms-agent/agent-local do.
I run them and it does present information, but how are these used if I put the scripts into:
/usr/lib/check_mk/local
What would I expect on the GUI front end? would I need to configure anything on the front end to support the scripts?
Thanks.
The rpm script, assuming you’re running an RPM package distro, should create a new a new tab on your device called Pkgs.
The dmi script just collects a bit more overview info.
With:
Without:
I don’t think you need to configure anything as long as your agent is accessible and the unix-agent module was properly detected and enabled for your device.
Hi slashdoom. I really appreciate your speedy response.
Yes I simply moved them into place, and the next run of the poller populated the details and added the pkgs tab.
Very nice.
Thanks again.
Hi. Just one more query.
I was able to perform this on all machines except the LibreNMS server itself, since the server itself doesn’t run check_mk so couldn’t run the “dmi” script with it (or the rpm script since it’s running CentOS 7).
What do I need to do to get these two check_mk plugin working for the LibreNMS server itself?
Thanks.
Maybe I’m misunderstanding but all you should have to do is install the agent on your LibreNMS server.
https://docs.librenms.org/#Extensions/Agent-Setup/
Follow the systemd steps if it is a CentOS7 box. Then just copy the scripts to the agent directory like you did with the other servers.
Hi slashdoom.
For an endpoint, the https://docs.librenms.org/#Extensions/Agent-Setup/ instructions are valid, but for the LibreNMS server itself, it’s not as the LibreNMS server has it’s own tree under /opt/librenms.
To clarify, for an endpoint following the git clone we have:
[root@endpoint ~]# ll /opt/librenms-agent/
total 88
drwxr-xr-x 2 root root 4096 Sep 2 2017 agent-local
-rwxr-xr-x 1 root root 22016 Sep 2 2017 check_mk_agent
-rw-r--r-- 1 root root 14225 Sep 2 2017 check_mk_agent_freebsd
-rw-r--r-- 1 root root 18063 Sep 2 2017 check_mk_COPYING
-rw-r--r-- 1 root root 140 Sep 2 2017 [email protected]
-rw-r--r-- 1 root root 126 Sep 2 2017 check_mk.socket
-rw-r--r-- 1 root root 2240 Sep 2 2017 check_mk_xinetd
drwxr-xr-x 2 root root 76 Sep 2 2017 debian
-rw-r--r-- 1 root root 639 Sep 2 2017 Makefile
-rwxr-xr-x 1 root root 1324 Sep 2 2017 mk_enplug
drwxr-xr-x 2 root root 4096 Sep 2 2017 snmp
For the LibreNMS server, it’s different and doesn’t have check_mk_agent as shown:
[root@librenms ~]# ll /opt/librenms/
total 2496
-rwxr-xr-x 1 librenms librenms 8572 Oct 31 2017 addhost.php
-rwxr-xr-x 1 librenms librenms 928 Nov 28 2017 adduser.php
-rwxr-xr-x 1 librenms librenms 1826 Jan 2 00:15 alerts.php
drwxrwxr-x 8 librenms librenms 111 May 31 15:01 app
-rw-rw-r-- 1 librenms librenms 1646 May 31 15:01 artisan
-rw-r--r-- 1 librenms librenms 10887 Jan 30 00:15 AUTHORS.md
-rw-r--r-- 1 librenms librenms 130 Apr 3 00:15 axisaudio_c3003.snmprec
-rwxrwxr-x 1 librenms librenms 6294 Sep 2 2017 billing-calculate.php
drwxrwxr-x 3 librenms librenms 51 May 31 15:01 bootstrap
-rwxr-xr-x 1 librenms librenms 1835 May 1 00:15 build-base.php
-rw-rw-r-- 1 librenms librenms 53935 Sep 2 2017 build.sql
drwxrwxr-x 2 librenms librenms 77 Jun 1 00:20 cache
-rw-r--r--. 1 librenms librenms 144 May 1 2016 CHANGELOG
-rwxr-xr-x 1 librenms librenms 1913 May 1 00:15 check-services.php
-rw-r--r-- 1 librenms librenms 249 Apr 3 00:15 ciena-sds_8700.snmprec
-rw-rw-r-- 1 librenms librenms 92 Sep 2 2017 CODE_OF_CONDUCT.md
-rw-rw-r-- 1 librenms librenms 3096 May 31 15:01 composer.json
-rw-rw-r-- 1 librenms librenms 174980 May 31 15:01 composer.lock
-rwxr-xr-x 1 librenms librenms 1849094 May 5 00:15 composer.phar
drwxrwxr-x 2 librenms librenms 4096 May 31 15:01 config
-rwxr-xr-x 1 librenms librenms 3126 Apr 29 23:02 config.php
-rw-r--r-- 1 librenms librenms 1834 Apr 3 00:15 config.php.default
-rwxrwxr-x 1 librenms librenms 253 Sep 2 2017 config_to_json.php
drwxr-xr-x. 2 librenms librenms 73 Sep 2 2017 contrib
-rw-rw-r-- 1 librenms librenms 171 Mar 7 17:43 CONTRIBUTING.md
-rwxrwxr-x 1 librenms librenms 876 Sep 2 2017 cronic
-rw-r--r-- 1 librenms librenms 9541 Apr 3 00:15 daily.php
-rwxrwxr-x 1 librenms librenms 10554 Mar 7 17:43 daily.sh
drwxrwxr-x 5 librenms librenms 51 May 31 15:01 database
-rwxrwxr-x 1 librenms librenms 566 Sep 2 2017 delhost.php
-rwxr-xr-x 1 librenms librenms 5074 Jan 30 00:15 discovery.php
-rwxrwxr-x 1 librenms librenms 13314 Mar 7 17:43 discovery-wrapper.py
-rwxrwxr-x 1 librenms librenms 2229 Sep 2 2017 dist-pollers.php
drwxr-xr-x. 10 librenms librenms 4096 Nov 28 2017 doc
drwxr-xr-x. 10 librenms librenms 4096 May 31 15:01 html
drwxr-xr-x. 10 librenms librenms 4096 May 31 15:01 includes
-rwxrwxr-x 1 librenms librenms 980 Sep 2 2017 irc.php
drwxr-xr-x. 11 librenms librenms 4096 Apr 3 00:15 lib
drwxrwxr-x 13 librenms librenms 4096 May 31 15:01 LibreNMS
-rw-rw-r-- 1 librenms librenms 490 Sep 2 2017 librenms.cron
-rw-r--r-- 1 librenms librenms 738 Nov 28 2017 librenms.nonroot.cron
drwxr-xr-x. 2 librenms librenms 48 May 1 2016 licenses
-rw-r--r--. 1 librenms librenms 35334 May 1 2016 LICENSE.txt
drwxrwxr-x+ 2 librenms librenms 91 Oct 31 2017 logs
drwx------ 2 librenms librenms 43 May 24 09:23 mail
-rw-r--r-- 1 librenms librenms 1506 Apr 3 00:15 Makefile
drwxr-xr-x. 170 librenms librenms 40960 May 31 15:01 mibs
drwxr-xr-x. 2 librenms librenms 4096 May 31 15:01 misc
-rw-rw-r-- 1 librenms librenms 6466 May 31 15:01 mkdocs.yml
-rw-rw-r-- 1 librenms librenms 1063 May 31 15:01 package.json
-rwxrwxr-x 1 librenms librenms 3841 Sep 2 2017 pbin.sh
-rw-rw-r-- 1 librenms librenms 1188 May 31 15:01 phpunit.xml
-rwxrwxr-x 1 librenms librenms 6329 Sep 2 2017 poll-billing.php
-rwxr-xr-x 1 librenms librenms 5910 May 1 00:15 poller.php
-rwxrwxr-x 1 librenms librenms 14369 Sep 2 2017 poller-service.py
-rwxr-xr-x 1 librenms librenms 13462 Nov 28 2017 poller-wrapper.py
-rw-rw-r-- 1 librenms librenms 480 Sep 2 2017 readmegen.yml
-rw-r--r-- 1 librenms librenms 10819 Oct 31 2017 README.md
-rwxrwxr-x 1 librenms librenms 845 Sep 2 2017 renamehost.php
drwxrwxr-x 5 librenms librenms 42 May 31 15:01 resources
drwxrwxr-x 2 librenms librenms 71 May 31 15:01 routes
drwxrwxr-x+ 13 librenms librenms 4096 Jun 1 11:04 rrd
drwxr-xr-x. 5 librenms librenms 4096 May 31 15:01 scripts
-rw-rw-r-- 1 librenms librenms 563 May 31 15:01 server.php
-rwxrwxr-x 1 librenms librenms 13274 Sep 2 2017 services-wrapper.py
-rw-rw-r-- 1 librenms librenms 65 Sep 2 2017 snmp.conf.example
-rw-rw-r-- 1 librenms librenms 791 May 31 15:01 snmpd.conf.example
-rwxrwxr-x 1 librenms librenms 8844 May 31 15:01 snmp-scan.py
-rwxrwxr-x 1 librenms librenms 993 Sep 2 2017 snmptrap.php
drwxr-xr-x. 2 librenms librenms 8192 May 31 15:01 sql-schema
drwxrwxr-x+ 6 librenms librenms 58 May 31 15:01 storage
-rwxrwxr-x 1 librenms librenms 602 Sep 2 2017 syslog.php
drwxr-xr-x. 6 librenms librenms 4096 May 31 15:01 tests
-rwxr-xr-x 1 librenms librenms 5926 May 1 00:15 validate.php
drwxrwxr-x 40 librenms librenms 4096 Jun 1 00:15 vendor
-rw-rw-r-- 1 librenms librenms 549 May 31 15:01 webpack.mix.js
So I can’t see how the git clone won’t clobber the /opt/librenms directory and possibly cause problems for the librenms install or future updates.
Should the instructions be updated to install the check_mk stuff into a directory other than /opt/librenms ?
Thanks.
It should be a different directory already. /opt/librenms vs. /opt/librenms-agent, right?
Hi slashdoom. Yes you are correct, I overlooked that.
Being in different directories, I went through and followed the process and all worked.
Really happy, good software
Thanks again.
