I am currently looking for a way to check if a service is running on a host.
Nagios has a script that checks with SNMP if a service is running or is dead. Process Checks
Is that possible to integrate something similar? People offered already a way to check if a service is running via ssh and a shell script but nagios showed that it should be possible via SNMP.
Do you need the snmp_extend.py on the LibreNMS Server and the monitoring script on the client or is the snmp_extend enough?
yes, snmp_extend.py on the LibreNMS Server …
… and script to check service on client and client configuration correct in client’s snmpd config file (simple snmp extend line to call the service monitoring script)
