Hey All,
I noticed over the weekend that my Cisco ASA device in LibreNMS is deleting all of it’s ports. The only thing I can think of that has changed was an unattended-upgrade of php8.1.2 (I really need to disable unattended-upgrade).
Everything else about the ASA (CPUs, Memory, Temps, Fans, VPNs, etc) is reporting properly other than all ports are now missing. I was able to see the missing ports under the global ports menu (at the top of the UI) in the Deleted section but, there’s no way that I can see to restore the ports.
I’ve done both Rediscover device, and Reset Port State on the ASA in LibreNMS multiple times but, it doesn’t seem to bring the ports back.
The only way I was able to make them return, temporarily, is to change “deleted” to 0 in the database itself in the ports table. But, on the next polling, they’re all deleted again.
Has anyone heard of this before and have any ideas how to fix it?
Validate output below:
| LibreNMS | 24.4.1-44-g1e3e60d59 (2024-05-08T23:17:05-04:00) |
| DB Schema | 2024_04_22_161711_custom_maps_add_group (292) |
| PHP | 8.1.2-1ubuntu2.17 |
| Python | 3.10.12 |
| Database | MariaDB 10.6.16-MariaDB-0ubuntu0.22.04.1 |
| RRDTool | 1.7.2 |
| SNMP | 5.9.1 |
[OK] Composer Version: 2.7.6
