Cisco Cat9K not detected properly and no NAC support
Hi
I have some Cisco Cat 9300.
For some reason, it seems like they are not detected properly
But they list the right model in Inventory tab
They have NAC enabled, but NAC, tab is not in the GUI even though the poller module is configured the right way.
Best Regards Mogens
The hardware field is filled by includes/polling/os/cisco.inc.php you can check that.
For NAC, you should probably include the poller debug output.
same issue with detecting the Hardware corretly .)
