Farenheit strikes again. Is there a setting in the switch to change Temperature units? Likely it stupidly affects the snmp output.
Probably the original author had F set, so I guess remove the translation in LibreNMS. Unless there is a way to tell the units of the output value from the device.
You didn’t understand what I said. LibreNMS always wants to work with Celsius unless told otherwise.
Whoever added the original sensors told LibreNMS that the values are in F. See here:
There has to be a reason they added it. I don’t have any clue about these devices and don’t have any so I can’t know the reasons. In order to innact change without breaking everyone, we would need to know the reason.
