Trying to add a cisco CBS350 model but Libre is reporting it as a generic device.
Here is the information required:
Discovery: https://p.libren.ms/view/8f4b9fec
Poller: https://p.libren.ms/view/9b7485d9
Thank you
Thank you
here is the snmpwalk link: https://p.libren.ms/view/550e7905
I am also having the same issue. Did you find any solution for this.
Hello
You can have a look here :
Bye
would it be possible to add the CBS 250 switch-line as well? As far as I understand the commit, at this file the folllowing line must be added:
includes/definitions/ciscosb.yaml
1.3.6.1.4.1.9.6.1.1005 (for the 10G version)
I think the 1G Uplink version should have the 1.3.6.1.4.1.9.6.1.1003. Would it make sense to add both lines?
As far as I understand on these files no additional commits are required?
The exact System OID is 1.3.6.1.4.1.9.6.1.1005.24.5. The model type is a CBS250-24P-4X 24-Port Gigabit PoE Smart Switch with 10G Uplinks (should be the system decription).
