I noticed that my IOS routers haven’t gathered PRI usage data since 24 January.
Component | Version |
LibreNMS | 1.54-66-g4fdf1618a |
DB Schema | 2019_07_09_150217_update_users_widgets_settings (140) |
PHP | 7.2.17-1+0~20190412071344.20+stretch~1.gbp23a36d |
MySQL | 10.1.37-MariaDB-0+deb9u1 |
RRDTool | 1.6.0 |
SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 1.9.0
Modified Files:
includes/polling/cisco-voice/cisco-iospri.inc.php
ciscp-iospri.in.php is modified because I’m doing echo() debugging.
Basically it fails the is_array() check on line 22 https://github.com/librenms/librenms/blob/master/includes/polling/cisco-voice/cisco-iospri.inc.php#L22
