Override poller modules: unix-agent, core, os, availability, ipmi, sensors, processors, mempools, storage, netstats, hr-mib, ucd-mib, ipSystemStats, ports, xdsl, customoid, bgp-peers, junose-atm-vp, printer-supplies, ucd-diskio, vminfo, wifi, wireless, ospf, isis, cisco-ipsec-flow-monitor, cisco-remote-access-monitor, cisco-cef, slas, cisco-mac-accounting, cipsec-tunnels, cisco-ace-loadbalancer, cisco-ace-serverfarms, cisco-asa-firewall, cisco-voice, cisco-cbqos, cisco-otv, cisco-qfp, cisco-vpdn, nac, netscaler-vsvr, aruba-controller, entity-physical, entity-state, applications, stp, ntp, loadbalancers, mef, mpls
SQL[select migration from migrations order by id desc limit 1 0.83ms]
SQL[select count(*) as aggregate from migrations 0.62ms]
SQL[select version() 0.51ms]
| Component |
Version |
| LibreNMS |
24.2.0-30-g8c4205c61 (2024-03-19T09:24:07+00:00) |
| DB Schema |
2024_02_07_151845_custom_map_additions (290) |
| PHP |
8.1.2-1ubuntu2.14 |
| Python |
3.10.12 |
| Database |
MariaDB 10.6.16-MariaDB-0ubuntu0.22.04.1 |
| RRDTool |
1.7.2 |
| SNMP |
5.9.1 |
Updating os_def.cache
Starting polling run:
SQL[select device_id from devices where hostname = ? [“192.168.44.46”] 0.73ms]
SQL[select * from devices where device_id = ? limit 1 [36] 0.68ms]
Hostname: 192.168.44.46 (cisco)
OS: iosxe
IP: 192.168.44.46
Attempting to initialize OS: iosxe
OS initialized: LibreNMS\OS\Iosxe
SQL[select * from devices_attribs where devices_attribs.device_id = ? and devices_attribs.device_id is not null [36] 0.61ms]
[FPING] ‘/usr/bin/fping’ ‘-e’ ‘-q’ ‘-c’ ‘3’ ‘-p’ ‘500’ ‘-t’ ‘500’ ‘-O’ ‘0’ ‘192.168.44.46’
response: xmt/rcv/%loss = 3/0/100%
SQL[insert into device_perf (min, max, avg, xmt, rcv, loss, debug, device_id, timestamp) values (?, ?, ?, ?, ?, ?, ?, ?, ?) [0,0,0,3,0,100,“{"poller_name":"nms"}”,36,“2024-04-26 05:54:00”] 1.14ms]
SQL[update devices set last_ping = ? where device_id = ? [“2024-04-26 05:54:00”,36] 0.77ms]
SQL[select * from device_outages where device_outages.device_id = ? and device_outages.device_id is not null and up_again is null order by going_down desc limit 1 [36] 0.59ms]
Load poller module availability
Module enabled: Global + | OS | Device | Manual
SQL[select * from device_outages where device_outages.device_id = ? and device_outages.device_id is not null and up_again >= ? order by going_down asc [36,1714024440] 0.65ms]
SQL[select * from availability where (device_id = ? and duration = ?) limit 1 [36,86400] 0.46ms]
SQL[update availability set availability_perc = ? where availability_id = ? [0,141] 0.4ms]
1 day : 0%
SQL[select * from device_outages where device_outages.device_id = ? and device_outages.device_id is not null and up_again >= ? order by going_down asc [36,1713506040] 0.65ms]
SQL[select * from availability where (device_id = ? and duration = ?) limit 1 [36,604800] 0.57ms]
SQL[update availability set availability_perc = ? where availability_id = ? [0,142] 0.41ms]
1 week : 0%
SQL[select * from device_outages where device_outages.device_id = ? and device_outages.device_id is not null and up_again >= ? order by going_down asc [36,1711518840] 0.71ms]
SQL[select * from availability where (device_id = ? and duration = ?) limit 1 [36,2592000] 0.42ms]
SQL[update availability set availability_perc = ? where availability_id = ? [0,143] 0.3ms]
1 month : 0%
SQL[select * from device_outages where device_outages.device_id = ? and device_outages.device_id is not null and up_again >= ? order by going_down asc [36,1682574840] 0.56ms]
SQL[select * from availability where (device_id = ? and duration = ?) limit 1 [36,31536000] 0.51ms]
SQL[update availability set availability_perc = ? where availability_id = ? [0,144] 0.3ms]
1 year : 0%
SQL[delete from availability where availability.device_id = ? and availability.device_id is not null and availability_id not in (?, ?, ?, ?) [36,141,142,143,144] 0.36ms]
SNMP: [0/0.00s] MySQL: [17/0.09s]
Runtime for poller module ‘availability’: 0.0181 seconds with 188392 bytes
Unload poller module availability
SQL[select * from device_graphs where device_graphs.device_id = ? and device_graphs.device_id is not null [36] 0.55ms]
Enabled graphs (18): uptime poller_modules_perf availability netstat_icmp netstat_icmp_info netstat_ip netstat_ip_frag netstat_snmp netstat_snmp_pkt netstat_udp netstat_tcp ipsystemstats_ipv4 ipsystemstats_ipv4_frag ipsystemstats_ipv6 ipsystemstats_ipv6_frag cisco-voice-ip poller_perf ping_perf
Start Alerts
SQL[select device_groups.*, device_group_device.device_id as pivot_device_id, device_group_device.device_group_id as pivot_device_group_id from device_groups inner join device_group_device on device_groups.id = device_group_device.device_group_id where device_group_device.device_id = ? [36] 0.5ms]
SQL[select exists(select * from alert_schedule where (start <= ? and end >= ? and (recurring = ? or (recurring = ? and ((time(start) < time(end) and time(start) <= ? and time(end) > ?) or (time(start) > time(end) and (time(start) <= ? or time(end) > ?))) and (recurring_day like ? or recurring_day is null)))) and (exists (select * from devices inner join alert_schedulables on devices.device_id = alert_schedulables.alert_schedulable_id where alert_schedule.schedule_id = alert_schedulables.schedule_id and alert_schedulables.alert_schedulable_type = ? and alert_schedulables.alert_schedulable_id = ?))) as exists [“2024-04-26T05:54:00.667220Z”,“2024-04-26T05:54:00.667220Z”,0,1,“05:54:00”,“05:54:00”,“05:54:00”,“05:54:00”,“%”,“device”,36] 0.92ms]
SQL[select * from devices where devices.device_id = ? limit 1 [36] 0.55ms]
SQL[SELECT DISTINCT a.* FROM alert_rules a
LEFT JOIN alert_device_map d ON a.id=d.rule_id AND (a.invert_map = 0 OR a.invert_map = 1 AND d.device_id = ?)
LEFT JOIN alert_group_map g ON a.id=g.rule_id AND (a.invert_map = 0 OR a.invert_map = 1 AND g.group_id IN (SELECT DISTINCT device_group_id FROM device_group_device WHERE device_id = ?))
LEFT JOIN alert_location_map l ON a.id=l.rule_id AND (a.invert_map = 0 OR a.invert_map = 1 AND l.location_id IN (SELECT DISTINCT location_id FROM devices WHERE device_id = ?))
LEFT JOIN devices ld ON l.location_id=ld.location_id AND ld.device_id = ?
LEFT JOIN device_group_device dg ON g.group_id=dg.device_group_id AND dg.device_id = ?
WHERE a.disabled = 0 AND (
(d.device_id IS NULL AND g.group_id IS NULL AND l.location_id IS NULL)
OR (a.invert_map = 0 AND (d.device_id=? OR dg.device_id=? OR ld.device_id=?))
OR (a.invert_map = 1 AND (d.device_id != ? OR d.device_id IS NULL) AND (dg.device_id != ? OR dg.device_id IS NULL) AND (ld.device_id != ? OR ld.device_id IS NULL))
) [36,36,36,36,36,36,36,36,36,36,36] 2.73ms]
Rule #1 (Device Down! Due to no ICMP response.):
SQL[SELECT * FROM devices WHERE (devices.device_id = ?) AND (devices.status = 0 && (devices.disabled = 0 && devices.ignore = 0)) = 1 AND devices.status_reason = “icmp” [36] 0.62ms]
SQL[SELECT state FROM alerts WHERE rule_id = ? AND device_id = ? ORDER BY id DESC LIMIT 1 [1,36] 0.33ms]
Status: NOCHG
SQL[SELECT alert_log.id, alert_log.details FROM alert_log,alert_rules WHERE alert_log.rule_id = alert_rules.id && alert_log.device_id = ? && alert_log.rule_id = ? && alert_rules.disabled = 0
ORDER BY alert_log.id DESC LIMIT 1 [36,1] 0.62ms]
SQL[UPDATE alert_log set details=? WHERE id = ? 0.86ms]
Rule #2 (Device Down (SNMP unreachable)):
SQL[SELECT * FROM devices WHERE (devices.device_id = ?) AND (devices.status = 0 && (devices.disabled = 0 && devices.ignore = 0)) = 1 AND devices.status_reason = “snmp” [36] 0.79ms]
SQL[SELECT state FROM alerts WHERE rule_id = ? AND device_id = ? ORDER BY id DESC LIMIT 1 [2,36] 0.39ms]
Status: NOCHG
Rule #3 (Device rebooted):
SQL[SELECT * FROM devices WHERE (devices.device_id = ?) AND devices.uptime < 300 AND (devices.disabled = 0 && devices.ignore = 0) = 1 [36] 0.48ms]
SQL[SELECT state FROM alerts WHERE rule_id = ? AND device_id = ? ORDER BY id DESC LIMIT 1 [3,36] 0.38ms]
Status: NOCHG
Rule #4 (Port status up/down):
SQL[SELECT * FROM devices,ports WHERE (devices.device_id = ? AND devices.device_id = ports.device_id) AND (ports.ifOperStatus = “down” && ports.ifAdminStatus != “down” && (ports.deleted = 0 && ports.ignore = 0 && ports.disabled = 0)) = 1 [36] 2.45ms]
SQL[SELECT state FROM alerts WHERE rule_id = ? AND device_id = ? ORDER BY id DESC LIMIT 1 [4,36] 0.41ms]
Status: NOCHG
ORDER BY alert_log.id DESC LIMIT 1 [36,4] 0.61ms]
SQL[UPDATE alert_log set details=? WHERE id = ? 1.06ms]
Rule #5 (Ping Latency):
SQL[SELECT * FROM devices WHERE (devices.device_id = ?) AND devices.last_ping_timetaken > 10 [36] 0.84ms]
SQL[SELECT state FROM alerts WHERE rule_id = ? AND device_id = ? ORDER BY id DESC LIMIT 1 [5,36] 0.49ms]
Status: NOCHG
Rule #6 (Port utilisation over threshold):
SQL[SELECT * FROM devices,ports WHERE (devices.device_id = ? AND devices.device_id = ports.device_id) AND (((SELECT IF(ports.ifOutOctets_rate>ports.ifInOctets_rate, ports.ifOutOctets_rate, ports.ifInOctets_rate)*8) / ports.ifSpeed)*100) >= 80 AND (ports.ifOperStatus = “up” && ports.ifAdminStatus = “up” && (ports.deleted = 0 && ports.ignore = 0 && ports.disabled = 0)) = 1 [36] 1.89ms]
SQL[SELECT state FROM alerts WHERE rule_id = ? AND device_id = ? ORDER BY id DESC LIMIT 1 [6,36] 0.52ms]
Status: NOCHG
Rule #7 (Sensor over limit - Check Device Health Settings):
SQL[SELECT * FROM devices,sensors WHERE (devices.device_id = ? AND devices.device_id = sensors.device_id) AND sensors.sensor_current > sensors.sensor_limit AND sensors.sensor_alert = 1 AND (devices.status = 1 && (devices.disabled = 0 && devices.ignore = 0)) = 1 [36] 1ms]
SQL[SELECT state FROM alerts WHERE rule_id = ? AND device_id = ? ORDER BY id DESC LIMIT 1 [7,36] 0.51ms]
Status: NOCHG
Rule #8 (Sensor under limit - Check Device Health Settings):
SQL[SELECT * FROM devices,sensors WHERE (devices.device_id = ? AND devices.device_id = sensors.device_id) AND sensors.sensor_current < sensors.sensor_limit_low AND sensors.sensor_alert = 1 AND (devices.status = 1 && (devices.disabled = 0 && devices.ignore = 0)) = 1 [36] 1.01ms]
SQL[SELECT state FROM alerts WHERE rule_id = ? AND device_id = ? ORDER BY id DESC LIMIT 1 [8,36] 0.51ms]
Status: NOCHG
Rule #9 (Service up/down):
SQL[SELECT * FROM devices,services WHERE (devices.device_id = ? AND devices.device_id = services.device_id) AND services.service_status != 0 AND (devices.status = 1 && (devices.disabled = 0 && devices.ignore = 0)) = 1 [36] 0.91ms]
SQL[SELECT state FROM alerts WHERE rule_id = ? AND device_id = ? ORDER BY id DESC LIMIT 1 [9,36] 0.51ms]
Status: NOCHG
Rule #10 (Wireless Sensor over limit):
SQL[SELECT * FROM devices,wireless_sensors WHERE (devices.device_id = ? AND devices.device_id = wireless_sensors.device_id) AND wireless_sensors.sensor_current >= wireless_sensors.sensor_limit AND wireless_sensors.sensor_alert = 1 AND (devices.status = 1 && (devices.disabled = 0 && devices.ignore = 0)) = 1 [36] 0.99ms]
SQL[SELECT state FROM alerts WHERE rule_id = ? AND device_id = ? ORDER BY id DESC LIMIT 1 [10,36] 0.51ms]
Status: NOCHG
Rule #11 (Wireless Sensor under limit):
SQL[SELECT * FROM devices,wireless_sensors WHERE (devices.device_id = ? AND devices.device_id = wireless_sensors.device_id) AND wireless_sensors.sensor_current <= wireless_sensors.sensor_limit_low AND wireless_sensors.sensor_alert = 1 AND (devices.status = 1 && (devices.disabled = 0 && devices.ignore = 0)) = 1 [36] 0.98ms]
SQL[SELECT state FROM alerts WHERE rule_id = ? AND device_id = ? ORDER BY id DESC LIMIT 1 [11,36] 0.5ms]
Status: NOCHG
Rule #12 (State Sensor Critical):
SQL[SELECT * FROM devices,sensors,sensors_to_state_indexes,state_indexes,state_translations WHERE (devices.device_id = ? AND devices.device_id = sensors.device_id AND sensors.sensor_id = sensors_to_state_indexes.sensor_id AND sensors_to_state_indexes.state_index_id = state_indexes.state_index_id AND state_indexes.state_index_id = state_translations.state_index_id) AND (sensors.sensor_current = state_translations.state_value && state_translations.state_generic_value = 2) = 1 AND sensors.sensor_alert = 1 [36] 1.69ms]
SQL[SELECT state FROM alerts WHERE rule_id = ? AND device_id = ? ORDER BY id DESC LIMIT 1 [12,36] 0.52ms]
Status: NOCHG
End Alerts (0.0621s)
Start Device Groups
SQL[select * from device_groups 0.48ms]
SQL[select * from device_group_device where device_group_device.device_id = ? [36] 0.53ms]
Groups Added: Removed:
End Device Groups (0.0028s)
Device was down, unable to poll.
