[Cisco WiFi virtual Controller] Manually add device to Oxidized
Laf,
This is what I got when I call the API like you said :
“hostname”: “192.168.x.y”,
“os”: “ciscowlc”,
“ip”: null,
“group”: “aireos”
“hostname”: “172.16.x.y”,
“os”: “moxa-etherdevice”,
“ip”: null
So ciscowlc are correctly mapped to aireos.
But they are not shown on oxidized’s GUI.
Regards,
Vincent
No that’s showing it’s mapped to a group, the OS hasn’t changed.
This is an example of an Arista device which has a mapping of arista_eos → eos:
        "hostname": "arista_eos",
        "os": "eos",
        "ip": null
If I update the mapping to eos1 then the os changes:
        "os": "eos1",
        "ip": null
Thanks laf. This works for me. :slight_smile:
Laf,
Oh, sorry for misreading. I’ll try it.
Vincent
Hello Laf,
That works for me. Thank you so much.
For records, I’ve just discovered this list (https://github.com/ytti/oxidized/blob/master/docs/Supported-OS-Types.md), which will help me a lot.
Thank again,
Vincent
