I have configured LibreNMS to use Alertmanager as the alert transport for sending alerts to a webhook.
I’ve noticed that whenever an alert transitions to “got better” or “got worse,” the unique ID field appears empty. Could you confirm if this is the expected behavior, or if it might be a potential bug?
/opt/librenms $ ./validate.php
| LibreNMS | 23.11.0 (2023-11-25T19:17:34+00:00) |
| DB Schema | 2023_11_04_125846_packages_increase_name_column_length (273) |
| PHP | 8.1.22 |
| Python | 3.10.13 |
| Database | MariaDB 10.5.24-MariaDB-1:10.5.24+maria~ubu2004 |
| RRDTool | 1.7.2 |
| SNMP | 5.9.3 |
[OK] MySQl and PHP time match
[OK] Redis is functional
Alert Template::::::::::::
Port HighUtilization---->
@php
// Custom query to fetch id from the alerts table based on device_id and timestamp
$customAlertId = DB::table(‘alerts’)
->where(‘device_id’, $alert->device_id)
->where(‘timestamp’, $alert->timestamp)
->value(‘id’);
@endphp
@if ($alert->state == 0)Time elapsed: {{ $alert->elapsed }} @endif
Unique-ID: {{ $customAlertId }}
@if ($alert->faults) Faults:
#{{ $loop->iteration }}: class_name: “Port”
specific_Problem: “HighUtilization”
instanceName: {{ $value[‘hostname’] }}/{{ $value[‘ifIndex’] }}
hostName: {{ $value[‘hostname’] }}
ipAddress: {{ $value[‘ip’] }}
severity: {{ $alert->severity }}
description: “Port HighUtilization for {{ $value[‘hostname’] }}/{{ $value[‘ifName’] }}”
@endforeach
@endif
Alert Rule:::::::::::::
Other PortUtilization OverThreshold---->
macros.port_up = 1 AND ports.ifType != “ethernetCsmacd” AND devices.os = “junos” AND (macros.port_in_usage_perc >= 90 OR macros.port_out_usage_perc >= 90)
JSONs:
below are the alert jsons taken from alert manager:
“annotations”: {
“description”: “Timestamp: 2025-04-02 08:26:03\nUnique-ID: \n Faults:\n #1: class_name: "Port"\n specific_Problem: "HighUtilization"\n instanceName: brmnc01xxxxxxxxxxxxxxxxxx/800\n hostName: brmnc01xxxxxxxxxxxxxxxxxx\n ipAddress: 10.65.xx.xx\n severity: warning\n description: "Port HighUtilization for brmnc01xxxxxxxxxxxxxxxxxx/irb.1052"\n #2: class_name: "Port"\n specific_Problem: "HighUtilization"\n instanceName: brmnc01xxxxxxxxxxxxxxxxxx/802\n hostName: brmnc01xxxxxxxxxxxxxxxxxx\n ipAddress: 10.65.xx.xx\n severity: warning\n description: "Port HighUtilization for brmnc01xxxxxxxxxxxxx/irb.1054"\n”,
“summary”: “Other PortUtilization OverThreshold”,
“title”: “Alert for device brmnc01xxxxxxxxxxxxxx - Other PortUtilization OverThreshold got worse”
“endsAt”: “2025-04-03T08:28:28.309Z”,
“fingerprint”: “ba9b41c694334a64”,
“receivers”: [
“name”: “alertmanager”
“startsAt”: “2025-04-02T08:02:04.000Z”,
“status”: {
“inhibitedBy”: ,
“silencedBy”: ,
“state”: “active”
“updatedAt”: “2025-04-02T08:28:28.309Z”,
“generatorURL”: “http://localhost/device/822”,
“labels”: {
“alertname”: “Other PortUtilization OverThreshold”,
“instance”: “brmnc01xxxxxxxxxxxxxxxxx”,
“severity”: “warning”,
“source_dns”: “dyxinxxxxxxxxxxxxxxxx”,
“source_type”: “librenms”
“annotations”: {
“description”: “Timestamp: 2025-04-01 21:34:03\nUnique-ID: \n Faults:\n #1: class_name: "Port"\n specific_Problem: "HighUtilization"\n instanceName: sbknc01xxxxxxxxxxxxxxxxxxx/690\n hostName: sbknc01xxxxxxxxxxxxxxxxxxx\n ipAddress: 10.65.xx.xx\n severity: warning\n description: "Port HighUtilization for sbknc01xxxxxxxxxxxxxxxxxxx/irb.1009"\n #2: class_name: "Port"\n specific_Problem: "HighUtilization"\n instanceName: sbknc01xxxxxxxxxxxxxxxxxxx/691\n hostName: sbknc01xxxxxxxxxxxxxxxxxxx\n ipAddress: 10.65.xx.xx\n severity: warning\n description: "Port HighUtilization for sbknc01xxxxxxxxxxxxxxxxxxx/irb.1010"\n #3: class_name: "Port"\n specific_Problem: "HighUtilization"\n instanceName: sbknc01xxxxxxxxxxxxxxxxxxx/692\n hostName: sbknc01xxxxxxxxxxxxxxxxxxx\n ipAddress: 10.65.xx.xx\n severity: warning\n description: "Port HighUtilization for sbknc01xxxxxxxxxxxxxxxxxxx/irb.1011"\n #4: class_name: "Port"\n specific_Problem: "HighUtilization"\n instanceName: sbknc01xxxxxxxxxxxxxxxxxxx/696\n hostName: sbknc01xxxxxxxxxxxxxxxxxxx\n ipAddress: 10.65.xx.xx\n severity: warning\n description: "Port HighUtilization for sbknc01xxxxxxxxxxxxxxxxxxx/irb.1045"\n #5: class_name: "Port"\n specific_Problem: "HighUtilization"\n instanceName: sbknc01xxxxxxxxxxxxxxxxxxx/697\n hostName: sbknc01xxxxxxxxxxxxxxxxxxx\n ipAddress: 10.65.xx.xx\n severity: warning\n description: "Port HighUtilization for sbknc01xxxxxxxxxxxxxxxxxxx/irb.1061"\n #6: class_name: "Port"\n specific_Problem: "HighUtilization"\n instanceName: sbknc01xxxxxxxxxxxxxxxxxxx/815\n hostName: sbknc01xxxxxxxxxxxxxxxxxxx\n ipAddress: 10.65.xx.xx\n severity: warning\n description: "Port HighUtilization for sbknc01xxxxxxxxxxxxxxxxxxx/irb.1052"\n #7: class_name: "Port"\n specific_Problem: "HighUtilization"\n instanceName: sbknc01xxxxxxxxxxxxxxxxxxx/817\n hostName: sbknc01xxxxxxxxxxxxxxxxxxx\n ipAddress: 10.65.xx.xx\n severity: warning\n description: "Port HighUtilization for sbknc01xxxxxxxxxxxxxxxxxxx/irb.1054"\n #8: class_name: "Port"\n specific_Problem: "HighUtilization"\n instanceName: sbknc01xxxxxxxxxxxxxxxxxxx/822\n hostName: sbknc01xxxxxxxxxxxxxxxxxxx\n ipAddress: 10.65.xx.xx\n severity: warning\n description: "Port HighUtilization for sbknc01xxxxxxxxxxxxxxxxxxx/irb.1238"\n #9: class_name: "Port"\n specific_Problem: "HighUtilization"\n instanceName: sbknc01xxxxxxxxxxxxxxxxxxx/823\n hostName: sbknc01xxxxxxxxxxxxxxxxxxx\n ipAddress: 10.65.xx.xx\n severity: warning\n description: "Port HighUtilization for sbknc01xxxxxxxxxxxxxxxxxxx/irb.1239"\n”,
“title”: “Alert for device sbknc01xxxxxxxxxxxxxxxxxxx - Other PortUtilization OverThreshold got better”
“endsAt”: “2025-04-02T21:36:53.129Z”,
“fingerprint”: “1bd62fa8b41df52b”,
“receivers”: [
“startsAt”: “2025-04-01T21:05:04.000Z”,
“status”: {
“inhibitedBy”: ,
“silencedBy”: ,
“state”: “active”
“updatedAt”: “2025-04-01T21:36:53.129Z”,
“generatorURL”: “http://localhost/device/402”,
“labels”: {
“instance”: “sbknc01xxxxxxxxxxxxxxxxxxx”,
“source_dns”: “dyxinfxxxxxxxxxxxx”,
