Messages based on warning rules are continuously being sent to Telegram. But there is actually no problem with the equipment. Can I clean or delete warning rule messages?
You are checking for syslog entries with messages containing EIGRP-IPv4 that match the macros.past_5m
Those are then sent with severity warning
If you want something else, you need to tweak your settings.
Consider filtering for the syslog alert level: syslog.level
Consider adding some additional conditions for the syslog.msg
