Composer problem
hello,
I have a problem with my Librenms running on Ubuntu 15.10.
When a run validate.php I have this :
[FAIL] No composer available, please install composer
[FIX] https://getcomposer.org/
I have installed composer but with no luck !
Thanks for your help.
regards.
I had the same problem.
I followed this advice:
After apt removing the package running ./validate.php again installed it for me, no more error.
Thanks !
The composer message have been gone after removing composer package.
I have now new problems with validate.php :
root@SRV:/opt/librenms# ./validate.php
LibreNMS 1.37-17-g5af51fa
DB Schema 238
PHP 5.6.11-1ubuntu3.2
MySQL 5.6.30-0ubuntu0.15.10.1
RRDTool 1.5.4
SNMP NET-SNMP 5.7.3
[OK] Composer Version: 1.6.3
[FAIL] You have not set sql_mode=’’ in your mysql config.
[FIX] Set sql-mode=’’ in your mysql config file in the [mysqld] section.
[FAIL] Database: incorrect column (users/updated_at)
[FAIL] Database: missing column (users/remember_token)
SQL Statements:
ALTER TABLE users CHANGE updated_at updated_at timestamp NOT NULL DEFAULT CURRENT_TIMESTAMP;
ALTER TABLE users ADD remember_token varchar(100) NULL AFTER updated_at;
@mourillostak you need to fix all that follow the commands its telling you.
@mourillostak Unrelated - but definitely not helping your cause - your server is beyond end of support - an upgrade to an LTS build (16.04) would be a positive move too.
