[OK] Composer Version: 1.8.6
[OK]
[OK] MySQl and PHP time match
[FAIL] No active polling method detected
bash-4.2$ ./daily.sh
Updating Composer packages FAIL
PHP Deprecated: Return type of Symfony\Component\Console\Helper\HelperSet::getIterator() should either be compatible with IteratorAggregate::getIterator(): Traversable, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in phar:///opt/librenms/composer.phar/vendor/symfony/console/Helper/HelperSet.php on line 112
PHP Deprecated: Optional parameter $schema declared before required parameter $path is implicitly treated as a required parameter in phar:///opt/librenms/composer.phar/vendor/justinrainbow/json-schema/src/JsonSchema/Constraints/UndefinedConstraint.php on line 62
bash-4.2$ composer dump-autoload
PHP Deprecated: Return type of Symfony\Component\Console\Helper\HelperSet::getIterator() should either be compatible with IteratorAggregate::getIterator(): Traversable, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in phar:///usr/local/bin/composer/vendor/symfony/console/Helper/HelperSet.php on line 112
Deprecation Notice: strlen(): Passing null to parameter #1 ($string) of type string is deprecated in phar:///usr/local/bin/composer/vendor/justinrainbow/json-schema/src/JsonSchema/Constraints/Constraint.php:48
Deprecation Notice: Return type of Composer\Repository\ArrayRepository::count() should either be compatible with Countable::count(): int, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in phar:///usr/local/bin/composer/src/Composer/Repository/ArrayRepository.php:277
Deprecation Notice: Return type of Symfony\Component\Finder\Finder::getIterator() should either be compatible with IteratorAggregate::getIterator(): Traversable, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in phar:///usr/local/bin/composer/vendor/symfony/finder/Finder.php:675
Deprecation Notice: Return type of Symfony\Component\Finder\Finder::count() should either be compatible with Countable::count(): int, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in phar:///usr/local/bin/composer/vendor/symfony/finder/Finder.php:732
Deprecation Notice: Return type of Symfony\Component\Finder\Iterator\FilterIterator::rewind() should either be compatible with FilterIterator::rewind(): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in phar:///usr/local/bin/composer/vendor/symfony/finder/Iterator/FilterIterator.php:30
Deprecation Notice: Return type of Symfony\Component\Finder\Iterator\FileTypeFilterIterator::accept() should either be compatible with FilterIterator::accept(): bool, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in phar:///usr/local/bin/composer/vendor/symfony/finder/Iterator/FileTypeFilterIterator.php:42
Deprecation Notice: Return type of Symfony\Component\Finder\Iterator\RecursiveDirectoryIterator::getChildren() should either be compatible with RecursiveDirectoryIterator::getChildren(): RecursiveDirectoryIterator, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in phar:///usr/local/bin/composer/vendor/symfony/finder/Iterator/RecursiveDirectoryIterator.php:85
Deprecation Notice: Return type of Symfony\Component\Finder\Iterator\RecursiveDirectoryIterator::rewind() should either be compatible with FilesystemIterator::rewind(): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in phar:///usr/local/bin/composer/vendor/symfony/finder/Iterator/RecursiveDirectoryIterator.php:113
Deprecation Notice: Return type of Symfony\Component\Finder\Iterator\RecursiveDirectoryIterator::current() should either be compatible with FilesystemIterator::current(): SplFileInfo|FilesystemIterator|string, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in phar:///usr/local/bin/composer/vendor/symfony/finder/Iterator/RecursiveDirectoryIterator.php:65
Deprecation Notice: Return type of Symfony\Component\Finder\Iterator\ExcludeDirectoryFilterIterator::accept() should either be compatible with FilterIterator::accept(): bool, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in phar:///usr/local/bin/composer/vendor/symfony/finder/Iterator/ExcludeDirectoryFilterIterator.php:55
Deprecation Notice: Return type of Symfony\Component\Finder\Iterator\ExcludeDirectoryFilterIterator::hasChildren() should either be compatible with RecursiveIterator::hasChildren(): bool, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in phar:///usr/local/bin/composer/vendor/symfony/finder/Iterator/ExcludeDirectoryFilterIterator.php:71
Deprecation Notice: Return type of Symfony\Component\Finder\Iterator\ExcludeDirectoryFilterIterator::getChildren() should either be compatible with RecursiveIterator::getChildren(): ?RecursiveIterator, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in phar:///usr/local/bin/composer/vendor/symfony/finder/Iterator/ExcludeDirectoryFilterIterator.php:76
Deprecation Notice: Return type of Symfony\Component\Finder\Iterator\FilterIterator::rewind() should either be compatible with Iterator::rewind(): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in phar:///usr/local/bin/composer/vendor/symfony/finder/Iterator/FilterIterator.php:30
Deprecation Notice: Return type of Symfony\Component\Finder\Iterator\DateRangeFilterIterator::accept() should either be compatible with FilterIterator::accept(): bool, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in phar:///usr/local/bin/composer/vendor/symfony/finder/Iterator/DateRangeFilterIterator.php:41
Deprecation Notice: Return type of Symfony\Component\Finder\Iterator\PathFilterIterator::accept() should either be compatible with FilterIterator::accept(): bool, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in phar:///usr/local/bin/composer/vendor/symfony/finder/Iterator/PathFilterIterator.php:27
Deprecation Notice: Return type of Symfony\Component\Finder\Iterator\FilenameFilterIterator::accept() should either be compatible with FilterIterator::accept(): bool, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in phar:///usr/local/bin/composer/vendor/symfony/finder/Iterator/FilenameFilterIterator.php:28
