Hello!
I am using the following alert to monitor 4G WAN backups when they go down.
SELECT * FROM devices,syslog
WHERE (devices.device_id = ? AND devices.device_id = syslog.device_id)
AND syslog.msg REGEXP “.WWAN1_GW\\\’ is Down.”
When a 4G backup goes down, it generates 1 syslog message containing “WWAN1_GW is Down” The alert works fine, but our issue is when the 4G module comes back up, these down alerts stay around.
I thought about using the syslog.timestap to recover alerts that are older than a given time, but this would clear alerts where the 4G module is still down.
When the 4G module comes back up, a syslog message is generated stating that it is up. Is it possible to have the alert recovery be conditional based on if it sees a new syslog message stating the 4G module is back up? I assume there might be other ways to achieve the same functionality.
Thanks in advance!
