We use Datacom Switches that Librenms don´t detect the vlan interface for graphing. I have a Zabbix template, but as I am not that good on programming, any one can help with this, without this we can´t bill customers as some ports have than one customer per interface ( vlans).
SNMP OID .1.3.6.1.4.1.3709.3.6.9.1.1.3.(1-256) ingress traffic counter
SNMP OID .1.3.6.1.4.1.3709.3.6.9.2.1.3.(1-256) egress traffic counter
root oid for discovery .1.3.6.1.4.1.3709.3.6.9.
<?xml version="1.0" encoding="UTF-8"?>
<zabbix_export>
<version>4.2</version>
<date>2019-10-08T19:44:04Z</date>
<groups>
<group>
<name>DmOS</name>
</group>
</groups>
<templates>
<template>
<template>DmOS - Interface Vlan</template>
<name>DmOS - Interface Vlan</name>
<description>Template para monitoramento em Vlan do DmOS</description>
<groups>
<group>
<name>DmOS</name>
</group>
</groups>
<applications>
<application>
<name>Interface Vlan</name>
</application>
</applications>
<items/>
<discovery_rules>
<discovery_rule>
<name>Network Vlan Discovery</name>
<type>4</type>
<snmp_community>{$SNMP_COMMUNITY}</snmp_community>
<snmp_oid>discovery[{#COUNTERINGRESSVALUE},.1.3.6.1.4.1.3709.3.6.9.1.1.2,{#COUNTEREGRESSVALUE},.1.3.6.1.4.1.3709.3.6.9.2.1.2]</snmp_oid>
<key>counters.discovery</key>
<delay>60s</delay>
<status>0</status>
<allowed_hosts/>
<snmpv3_contextname/>
<snmpv3_securityname/>
<snmpv3_securitylevel>0</snmpv3_securitylevel>
<snmpv3_authprotocol>0</snmpv3_authprotocol>
<snmpv3_authpassphrase/>
<snmpv3_privprotocol>0</snmpv3_privprotocol>
<snmpv3_privpassphrase/>
<params/>
<ipmi_sensor/>
<authtype>0</authtype>
<username/>
<password/>
<publickey/>
<privatekey/>
<port/>
<filter>
<evaltype>0</evaltype>
<formula/>
<conditions/>
</filter>
<lifetime>5d</lifetime>
<description/>
<item_prototypes>
<item_prototype>
<name>Interface Vlan {#COUNTEREGRESSVALUE}: Bytes OUT</name>
<type>4</type>
<snmp_oid>.1.3.6.1.4.1.3709.3.6.9.2.1.3.{#SNMPINDEX}</snmp_oid>
<key>counters.egress[countersEgressValue.{#SNMPINDEX}]</key>
<delay>60s</delay>
<history>90d</history>
<trends>365d</trends>
<status>0</status>
<value_type>3</value_type>
<allowed_hosts/>
<units>bps</units>
<params/>
<ipmi_sensor/>
<username/>
<password/>
<publickey/>
<privatekey/>
<port/>
<description/>
<inventory_link>0</inventory_link>
<applications>
<application>
</application>
</applications>
<valuemap/>
<logtimefmt/>
<preprocessing>
<step>
<type>10</type>
<params/>
<error_handler>0</error_handler>
<error_handler_params/>
</step>
<step>
<type>1</type>
<params>8</params>
</step>
</preprocessing>
<jmx_endpoint/>
<timeout>3s</timeout>
<url/>
<query_fields/>
<posts/>
<status_codes>200</status_codes>
<follow_redirects>1</follow_redirects>
<post_type>0</post_type>
<http_proxy/>
<headers/>
<retrieve_mode>0</retrieve_mode>
<request_method>0</request_method>
<output_format>0</output_format>
<allow_traps>0</allow_traps>
<ssl_cert_file/>
<ssl_key_file/>
<ssl_key_password/>
<verify_peer>0</verify_peer>
<verify_host>0</verify_host>
<application_prototypes/>
<master_item/>
</item_prototype>
<item_prototype>
<name>Interface Vlan {#COUNTERINGRESSVALUE}: Bytes IN</name>
<type>4</type>
<snmp_oid>.1.3.6.1.4.1.3709.3.6.9.1.1.3.{#SNMPINDEX}</snmp_oid>
<key>counters.ingress[countersIngressValue.{#SNMPINDEX}]</key>
<delay>60s</delay>
<status>0</status>
<allowed_hosts/>
<units>bps</units>
<params/>
<ipmi_sensor/>
<username/>
<password/>
<publickey/>
<privatekey/>
<port/>
<description/>
<applications>
<application>
</application>
</applications>
<valuemap/>
<logtimefmt/>
<preprocessing>
<step>
<type>10</type>
<params/>
</step>
<step>
<type>1</type>
<params>8</params>
</step>
</preprocessing>
<jmx_endpoint/>
<url/>
<query_fields/>
<posts/>
<http_proxy/>
<headers/>
<ssl_cert_file/>
<ssl_key_file/>
<ssl_key_password/>
<master_item/>
</item_prototype>
</item_prototypes>
<trigger_prototypes/>
<graph_prototypes>
<graph_prototype>
<name>Interface {#COUNTERINGRESSVALUE}({#COUNTEREGRESSVALUE}): Network traffic</name>
<width>900</width>
<height>200</height>
<yaxismin>0.0000</yaxismin>
<yaxismax>100.0000</yaxismax>
<show_work_period>1</show_work_period>
<show_triggers>1</show_triggers>
<type>0</type>
<show_legend>1</show_legend>
<show_3d>0</show_3d>
<percent_left>0.0000</percent_left>
<percent_right>0.0000</percent_right>
<ymin_type_1>0</ymin_type_1>
<ymax_type_1>0</ymax_type_1>
<ymin_item_1>0</ymin_item_1>
<ymax_item_1>0</ymax_item_1>
<graph_items>
<graph_item>
<sortorder>0</sortorder>
<drawtype>5</drawtype>
<color>1A7C11</color>
<yaxisside>1</yaxisside>
<calc_fnc>2</calc_fnc>
<type>0</type>
<item>
<host>DmOS - Interface Vlan</host>
</item>
</graph_item>
<graph_item>
<sortorder>1</sortorder>
<color>2774A4</color>
<type>0</type>
<item>
</item>
</graph_item>
</graph_items>
</graph_prototype>
</graph_prototypes>
<host_prototypes/>
<jmx_endpoint/>
<url/>
<query_fields/>
<posts/>
<http_proxy/>
<headers/>
<ssl_cert_file/>
<ssl_key_file/>
<ssl_key_password/>
<lld_macro_paths/>
<preprocessing/>
<master_item/>
</discovery_rule>
</discovery_rules>
<httptests/>
<macros/>
<templates/>
<screens/>
<tags/>
</template>
</templates>
</zabbix_export>
