I’m trying to convert my existing alerting templates to the new format and am absolutely stuck trying to get them to be accepted. They’re all fairly similar so I’m figuring if I can get some direction on where I’m going wrong with one of them I should be able to get the rest to work. Here’s the one that I use for device up/down (after running through the convert):
@if ($alert->transport == mail) <b>{{ $alert->title }}</b><br>
<b>Severity:</b> {{ $alert->severity }}<br>
@if ($alert->state == 0) <b>Time elapsed:</b> {{ $alert->elapsed }}<br> @endif
<b>Timestamp:</b> {{ $alert->timestamp }}<br>
<b>Rule:</b> @if ($alert->name) {{ $alert->name }} @else {{ $alert->rule }} @endif <br>
@if ($alert->faults) <b>Faults:</b>
{{ $alert->hostname }} is @if ($alert->state == 1) down @else up @endif <br> @endif
<b>Alert sent to:</b> @foreach ($alert->contacts as $key => $value){{ $value }} <{{ $key }}> @endforeach
@endif
@if ($alert->transport == msteams)
@if ($alert->state == 0) Time elapsed: {{ $alert->elapsed }} @endif
@if ($alert->faults) Faults: {{ $alert->hostname }} is @if ($alert->state == 1) down @else up @endif @endif
@endif
I get a syntax error alert when trying to save the template but no other real guidance. I’ve got through the new documentation and the linked Laravel documentation and I can’t see anything glaring that I’m doing wrong. I’m sure it’s something fairly simple that I’m just overlooking.
