Is there anyway to copy a dashboard along with the widgets to make another dashboard that can be modified as needed?
Here might be a good example -
Let’s say you have the same equipment at multiple geographical sites and you want to create a dashboard for each site. Instead of creating a new dashboard from scratch for each site along with widgets, you could simply clone a dashboard and modify the widgets as needed.
Is this possible?
