Copying, or templating custom OIDs
I am currently graphing several OIDs for a single device via CustomOIDs. These OIDs are not pre-canned in the default suite of OIDs. I will need to graph these custom OIDs on a couple of similar devices. Is there any way to copy those customOIDs to other devices, or template the customOIDs for use across a fleet of similar devices?
Hi @jimbob
The only good solution here is to include them in LibreNMS standard polling. It will be much faster than playing with CustomOIDs. CustomOIDs were developped only for temporary usecases. If you want to do it more than once, basically, implement and submit it to LibreNMS (and then all other users will enjoy this data as well after an upgrade)
