After my ubuntu upgrade : 19.04 to 19.10, I have an error ./validate.php :
Component | Version |
LibreNMS | 1.57-86-g4ead80d06 |
DB Schema | Not Connected (0) |
PHP | 7.2.24-0ubuntu0.19.04.1 |
MySQL | ? |
RRDTool | 1.7.1 |
SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 1.9.1
Your PHP is missing required mysql extension(s), please install and enable.
Check the install docs for more info: https://docs.librenms.org/Installation/
I tryed to compare creditential in config.php and .env but it’s correct.
My service mariadb is active and I can login to my database.
Can you help me ?
