CPU's not detected?
Hi. Odd issue I am having. I added a couple of CentOS 7 machines to LibreNMS, which I’ve literally done a hundred times now :slight_smile: … and the CPU’s aren’t detected? so there’s no processor graphs etc.
It’s running as a VM guest (as 99% of every other CentOS 7 machine), using KVM64. On the same physical VM host, I have other CentOS 7 machines built the same way, that work fine and show their processors.
How do I trouble-shoot this one?
When I go to Cog -> Edit -> Processors, it says “no results found”.
Thanks.
Hi. I’ve solved it. I went ahead and did a “rediscover device” and the CPU’s came up.
Go figure!
