Crash after daily upgrade
Hi
My librenms crashed after daily upgrade 2025.03.27.
./validate.php
PHP Fatal error: Uncaught ReflectionException: Class “librenms-config” does not exist in /var/www/html/librenms/vendor/laravel/framework/src/Illuminate/Container/Container.php:912
Stack trace:
#0 /var/www/html/librenms/vendor/laravel/framework/src/Illuminate/Container/Container.php(912): ReflectionClass->__construct()
#1 /var/www/html/librenms/vendor/laravel/framework/src/Illuminate/Container/Container.php(795): Illuminate\Container\Container->build()
#2 /var/www/html/librenms/vendor/laravel/framework/src/Illuminate/Container/Container.php(731): Illuminate\Container\Container->resolve()
#3 /var/www/html/librenms/vendor/laravel/framework/src/Illuminate/Foundation/helpers.php(120): Illuminate\Container\Container->make()
#4 /var/www/html/librenms/LibreNMS/Util/Version.php(52): app()
#5 /var/www/html/librenms/validate.php(162): LibreNMS\Util\Version::get()
#6 /var/www/html/librenms/validate.php(83): print_header()
#7 [internal function]: {closure}()
#8 {main}
php -v
PHP 8.2.20 (cli) (built: Jun 17 2024 13:33:14) (NTS)
Copyright (c) The PHP Group
Zend Engine v4.2.20, Copyright (c) Zend Technologies
with Zend OPcache v8.2.20, Copyright (c), by Zend Technologies
Any idea ?
Zoltan
Try running ./scripts/composer_wrapper.php install --no-dev
I have the same issue, and laf’s suggestion didn’t solve it for me.
weird:
Yesterday i added “$config[‘rrdtool_version’] = ‘1.5.5’;” to the config
after removing this the issue cleared.
We got this issue some days ago, and again today. NMS web interface was not not working (blank page).
I ran daily.sh manually, got lot of errors related to php, then the daily.sh updated composer and Librenms was back again …
The main issue is NO monitoring from crash time till begining of the day (several hours).
What is the root cause ? and how to update librenms without killing the whole monitoring system ?
We use librenms to monitor customer’s routers and we need a stable system at anytime :frowning:
daily.sh is all that’s need to update cleanly.
