I need to create an alert who everymonth (for example) sending a message like “certificate expired”.
is it possible ?
Thank you
is it possible ?
Thank you
Not by default as it falls outside SNMP monitoring,
LibreNMS supports Nagios, so it might be possible to alert via Nagios integration
#https://docs.librenms.org/Extensions/Services/
#https://www.linuxincluded.com/monitor-for-expired-ssl-tls-certs-with-nagios/
