Create a device group / alert for sensor NOT existing
Hey, I am trying to create an alert to notify me about Juniper switches that have only 1 power supply.
So for example a device with two power supplies will look like this:
WhatsApp Image 2024-12-30 at 17.37.36
But a device with only one will look like this:
WhatsApp Image 2024-12-30 at 17.37.35
Power Supply 0 @ 0/0/* sensor is not even created.
WhatsApp Image 2024-12-30 at 17.37.47
I did find a bunch of info about Power Supply 0 @ 0/0/* anf Power Supply 1 @ 0/1/* sensors using API but I don’t know how I can use the “sensor_index” or “sensor_oid” to create an alert that would work for devices which have one of the two sensors, but not both.
If the sensor doesn’t exist in the database then you can’t alert on it by default. You’d need to write a custom SQL query that does a count on rows matching the description of the power supplies and alert if they are < 2.
OK, with the help of ChatGPT and MySQLWorkbench I ended up with:
SELECT *
FROM devices
JOIN (
    SELECT devices.device_id, COUNT(DISTINCT sensors.sensor_descr) AS unique_power_supply_sensor_count
    FROM devices
    JOIN sensors ON devices.device_id = sensors.device_id
    WHERE sensors.sensor_descr LIKE '%Power Supply%' AND devices.device_id = ?
    GROUP BY devices.device_id
    HAVING unique_power_supply_sensor_count < 3
) AS subquery ON devices.device_id = subquery.device_id;
I don’t really have any SQL experience, it seems a bit long, but also seems to work fine. If anyone has any ideas how to simplify the query please let me know.
