Hi.
I would like to create a custom plug (which kind of works right now).
It’s basically just pulling data from the database using a custom query
$devices_sql = dbFetchRows("SELECT
`D`.`sysName` AS `sysName`,
`D`.`hardware` AS `hardware`,
`S`.`sensor_class` AS `sensor_class`,
`S`.`sensor_current` AS `sensor_current`
FROM `devices` AS `D`
INNER JOIN `wireless_sensors` AS `S` ON `D`.`device_id`=`S`.`device_id`");
I would like to put this data into the standard tables I see all across librenms, is there any documentation about how the tables work? Basically, the wireless sensors are fine, but I would like to filter by device types as well which I can’t currently do.
Is there any documentation about how this works? I see requests going to /ajax/table/device but honestly, I’m a bit lost as to how to format this correctly to allow filtering and refreshing?
