Hi
I see that Librenms creates graphs for all discovered interfaces, could it be possible to create graphs only for selected interfaces, cause i would or may not need graphs for all interfaces, and besides its also could curb the disk space used for creating graphs, i am looking to replace cacti, wish this was possible
Clifford Dsouza
You can on the dashboard using the widgets. Look in the docs for dashboards.
I think he wants to sort out specific interfaces.
Therefore you can define them on the config file as bad_if. Just have a look at the docs, it’s written in there.
Hi Jarod
I guess im not getting it, i.e. the bad_if stuff, lets say we have 48 interface detected by librenms when we add a device, however i need the graphs or polling for statistics for only 2 interfaces, like i can do with cacti, example cacti can list my interfaces and then i can decide to graph or get statistics for only the interface i need.
Regards
Clifford Dsouza
