I don’t think that my /etc/cron.d/librenms cron job is running. Is this because I am also using the system crontab?
First thing that I noticed was that my daily updates are not running automatically because my GUI was inaccessible a few weeks ago and I just updated it to resolve it.
Second thing I noticed… I’ve been trying to tweak my poller threads because my performance seems very slow and even after increasing and decreasing the count on the poller-wrapper.py cron (*/5 * * * * librenms /opt/librenms/cronic /opt/librenms/poller-wrapper.py 16) It doesn’t seem to make a difference. If I run poller-wrapper manually, it still states that it is running at the default 16. Also, when I checked the logs, I get this message:
Cronic detected failure or error output for the command:
RESULT CODE: 2
ERROR OUTPUT:
STANDARD OUTPUT:
ERROR: Could not load or parse configuration, are PATHs correct?
Any other way to confirm cronjob is running?
Post your /etc/cron.d/librenms
everything should be in there and nowhere else.
Also, you need to run ./validate.php and post it.
./validate.php
Component |
Version |
LibreNMS |
1.48.1-85-gee76057 |
DB Schema |
2019_02_10_220000_add_dates_to_fdb (132) |
PHP |
7.2.14 |
MySQL |
5.5.60-MariaDB |
RRDTool |
1.4.8 |
SNMP |
NET-SNMP 5.7.2 |
[OK] Composer Version: 1.8.4
Using this cron file requires an additional user on your system, please see install docs.
*/5 * * * * librenms /opt/librenms/cronic /opt/librenms/poller-wrapper.py 8
- librenms /opt/librenms/alerts.php >> /dev/null 2>&1
00 09 * * * librenms /opt/fixrights.sh
Daily maintenance script. DO NOT DISABLE!
If you want to modify updates:
15 0 * * * librenms /opt/librenms/daily.sh >> /dev/null 2>&1
I’ve changed the thread to see if that makes a difference today.
When I run poller-wrapper it still says:
INFO: starting the poller at 2019-02-26 10:09:15 with 16 threads, slowest devices first
