I am looking into high CPU usage on our setup and the cron job I setup years ago might be the problem. I don’t really know if this setup is what should be done now and if anything should be removed. It was years ago I set this up and the documentation seems to have changed a lot. We have 1400 devices and are aiming for 1-5min polling.
# Using this cron file requires an additional user on your system, please see install docs.
33 */6 * * * librenms /opt/librenms/cronic /opt/librenms/discovery-wrapper.py 2
*/5 * * * * librenms /opt/librenms/cronic /opt/librenms/poller-wrapper.py 32
* * * * * librenms /opt/librenms/alerts.php >> /dev/null 2>&1
# Daily maintenance script. DO NOT DISABLE!
# If you want to modify updates:
# Switch to monthly stable release: https://docs.librenms.org/General/Releases/
# Disable updates: https://docs.librenms.org/General/Updating/
15 0 * * * librenms /opt/librenms/daily.sh >> /dev/null 2>&1
| LibreNMS | 24.2.0 (2024-02-27T11:54:10-07:00) |
| DB Schema | 2024_02_07_151845_custom_map_additions (290) |
| PHP | 8.1.2-1ubuntu2.14 |
| Python | 3.10.12 |
| Database | MariaDB 10.6.16-MariaDB-0ubuntu0.22.04.1 |
| RRDTool | 1.7.2 |
| SNMP | 5.9.1 |
[OK] Composer Version: 2.7.1
