When I go to an interface traffic graph and manually select a custom start and end date/time, the graph doesn’t show the period I selected. It always shows around 24 hours instead.
The predefined periods, like 24 Hours, 1 Week, 1 Month, etc., work correctly. The problem only happens when using a custom date/time range.
For example, I can manually select a period of one week or one month, but after applying it, the graph still only displays around 24 hours of data.
This happens every time I try to use a custom period.
Expected: The graph should show the exact custom start and end date/time selected
Actual: The graph shows only around 24 hours
./validate.php output:
LibreNMS | 26.7.0-dev.118+9be807158 (2026-07-09T20:39:53+01:00)
DB Schema | 2026_06_17_230632_migrate_status_reason_format_in_rules_and_templates (393)
PHP | 8.4.23
Python | 3.10.12
Database | MariaDB 10.6.23-MariaDB-0ubuntu0.22.04.1
RRDTool | 1.7.2
SNMP | 5.9.1
[OK] Composer Version: 2.10.2
