Would it be possible to add the option of changing the line size for an EDGE ?
At my age I can’t see very well ![]()
Regards,
Afaik, line width is based on port speed.
Are you sure ? I didn’t see that.
Regards
Do you think that is possible to add this feature in the future ?
Regards
Or maybe enable to modify configuration of VisJS by config.php, like Network Map :
I tried to look the code but i don’t have enough development skills ![]()
Regards
