I created a custom map and started adding nodes to it. It worked OK until I added a third node, then in View mode it’s just rendering as a blank white rectangle [not a very useful screenshot…]:
I removed the third node but it made no difference. The map renders fine in edit mode. I set the background to orange, but view mode is still white.
There are no errors in nginx access.log or librenms.log.
On the developer tools console we have:
Uncaught TypeError: Arrays are not supported by deepExtend
selectiveNotDeepExtend http://venus/js/vis.min.js:25
value http://venus/js/vis.min.js:42
setOptions http://venus/js/vis.min.js:40
o http://venus/js/vis.min.js:40
createNetwork http://venus/maps/custom/1:783
refreshMap http://venus/maps/custom/1:997
interval http://venus/maps/custom/1:1029
setInterval handler*Start http://venus/maps/custom/1:1026
<anonymous> http://venus/maps/custom/1:1041
jQuery
Automatic maps work fine [well, show lots of nodes anyway].
