NOTE: I love the custom map feature!!! Thank you
I work for an ISP and we have 20+ sites. Most sites are configured similarly and have the same type of equipment in them.
Currently, when I try to add an edge from 2 nodes that neither are devices nothing populates under the select port drop down. I have tried searching by name, port index number, etc… No luck.
Is there a way to have the “Link to Map” function added to the node when I choose the device? It seems to currently be either Link to map or device.
Example: When I click on “alp-cj1” it would take me directly to the ALP-Hut custom map.
