I recently tried the Maps - Custom maps menu to place my wifi APs.
I am trying to load a background by floors (Set background) in .jpng .png with a classic dimension 1800px * 800px but it never appears.
Do you have any idea of the problem?
Thanks a lot !
The new “custom map” menu is not accessible for users with the “User” role.
How can we add it?
This is a screenshot, with the error: Flasher is not loaded ?
In the librenms logs, I also have this error message :
The file "/applis/librenms/html/images/custommap/background/3_20.png" does not exist {"userId":8,"exception":"[object] (Symfony\\Component\\HttpFoundation\\File\\Exception\\FileNotFoundException(code: 0): The file \"/applis/librenms/html/images/custommap/background/3_20.png\" does not exist at /applis/librenms/vendor/symfony/http-foundation/File/File.php:36)"}
I hope to find the solution
It’s a do-it-yourself solution
I renamed my background and copied it directly into librensnms
#/applis/librenms/html/images/custommap/background/3_20.png
There’s a naming convention, example: 3_20.png
- 3 = the map number, visible in the URL or logs:
- 20 = the map version number, visible in the logs
If a patch is forthcoming, thanks to you.
