Custom Maps
I love the custom maps feature, for my use case it fits nearly all my needs. I do wish it had the following abilities:
  1. Multiple select and edit, it would be nice to have the ability to change a bunch of links from percent utilization to mbps in one edit.
  2. Multiple select and move, I know you can pick devices one at a time, however if you need to move 10 objects and their associated edge links this is a time consuming/error prone task. It would be amazing to have a multi-select feature where you can use your mouse and a drag-able box to highlight the objects and move them.
  3. Minor issue, the graph that comes up is the mini graph that does not have x and y labels. I wish this used a graph that had the labels.
  4. When you add a map on a dashboard, it would be nice to be able to click on the map and open it full full screen.
Thanks again!
Chris
