Hi guys I have tried to import new MIB files but cant figure out how to tell librenms toto use a specifi mib for devices. I cant seem to find docs on this either.
LibreNMS is not MIB based. Just adding a MIB will do nothing it needs to be coded into the device os.yaml
If you are trying to add support for a new device do the following.
MMM ok Ill give this a go. By the way how is LiberNMS support for ubiquiti? It is specifically for these devices that I want to add graphs because data I currently get is not correct. I am working with AirOS8 and 7
Also doe the files name have to be puls,yaml? What if I whant to create a second and third OS
The yaml file name must match the OS name itself. If a device runs an entirely different OS then it needs a new OS detection creating, if it’s just a different revision or firmware then it stays as the same OS.
Hi Kevin, I am creating software to perform authorization and automatic provisioning in OLT of Huawei and ZTE, I see that you have a lot of experience in this field, we want to contact you to hire your professional services, please tell us how we can proceed.
