Hi there,
I have added a custom OID - Anti Bot Update for Checkpoint. But the Custom OID does not Graphing. When I run Test OID, it returned a value “up-to-date” received. Do I miss anything here? Thanks very much!
Regards
Jeff Deng
Hello.
If the OID does not return a numerical value, you cannot graph the output.
The graphs represent a two-dimensional plot (value as a function of time).
If you know the different possible states, you can configure check_snmp (by installing the Nagios plugins) as a service and check it there.
The output will be integer values, which can be graphed.
I leave you a couple of references on how to install the plugins:
https://raymii.org/s/tutorials/Service_checks_in_LibreNMS_nagios_plugins.html
And the official documentation for the check_snmp plugin:
Greetings
