Custom OID's Sensors
I need to monitor an OID on a device that I don’t think should be added as a standard sensor. It is a door open/close sensor that is hooked into an Eltek device. I found https://github.com/librenms/librenms/pull/7925 and this seems like it would do what I’m looking for, but I’m not sure if I should comment on that asking for an update or here so I chose here.
Any updates on this?
Can I pull grab this from git and test it out. I’m not too familiar with git and I’ve done some googling and can’t seem to figure out if that’s possible or not.
Does the Eltek mib indicate what kind of sensor it is? If so, built in support can be added?
It’s a programmable input on the device that you can use with any type of sensor. I know the OID of it from looking at the previous NMS system, but I’m not sure that helps.
.1.3.6.1.4.1.12148.10.11.2.1.2.1.6
I’ve reached out to the manufacturer to see if I can get the MIB files.
