The ability to create a custom view/pane on the device page using a SQL query. Since the read out for some of these panes like VLANs is a SQL query. And additional option further apply these to an entire device type. So all juniper gear could have this pane or device group.
The second part would be a top level view.
Same concept but you could use a broader set of info across multiple devices.
