Custom widgets
Where can I find information on creating custom dashboard widgets?
Unfortunately, there is no documentation on that. You can look for the other widgets in the code and copy them.
So I got to the point where I did a widget seed, added a widget id in the database, created an inc file and a blade file.
This is all fine. I can put a widget on a dashboard. But now I get a message saying “problem with backend”
Any hints or tips on where to go from there?
/opt/librenms/includes/html/table/devicepower-stats.inc.php
/opt/librenms/resources/views/widgets/settings/devicepower_stats.blade.php
/opt/librenms/resources/views/widgets/devicepower_stats.blade.php
/opt/librenms/app/Http/Controllers/Widgets/DevicePowerStatsController.php
/opt/librenms/database/seeds/DefaultWidgetSeeder.php
Check logs/librenms.log should indicate where the error is. Or view the output of the ajax request.
I think I got it. The hardest part was just figuring out how everything lined up and it took a bit to figure out that I had to run composer. All I was getting was error 404 for my widget when I was expecting 500 or something else.
After running the composer again the widget started populating with data.
