Custom YAML file for Eaton EILB13
Hello Everyone,
im doing mine internship in a datacenter nearby.
As intern i have got mine own project to work on.
We want to monitor inline current meters from Eaton (EILB13) and we already making use of LibreNMS to monitor some servers. so i looked it up and i saw that is was possible to intergrate the current meters in LibreNMS.
After i made a test environment and added the current meter i found out that is was everything i want to monitor so i tried to make my own YAML file for the discovery and so far everything i want to monitor shows up except the Current and the load.
Does anyone know what im doing wrong?
Here is the YAML file i currently have:
mib: PDU-MIB:EATON-EPDU-MIB
modules:
  os:
    hardware:
      - EATON-EPDU-MIB::partNumber.0
      - PDU-MIB::objectName.0
    hardware_template: "{{ EATON-EPDU-MIB::partNumber.0 }} {{ PDU-MIB::objectName.0 }}"
    serial:
      - EATON-EPDU-MIB::serialNumber.0
      - PDU-MIB::serialNumber.0
    version:
      - EATON-EPDU-MIB::firmwareVersion.0
      - PDU-MIB::firmwareVersion.0
  sensors:
    #works correctly
    frequency:
      data:
        - oid: inputTable
          value: inputFrequency
          num_oid: ".1.3.6.1.4.1.534.6.6.7.3.1.1.3.{{ $index }}"
          divisor: 10
          index: "inputFrequency.{{ $index}}"
          descr: "Frequency"
    #works correctly
    voltage:
      data:
        - oid: inputVoltageTable
          value: inputVoltage
          num_oid: ".1.3.6.1.4.1.534.6.6.7.3.2.1.3.{{ $index }}"
          divisor: 1000
          descr: "Current Voltage"
          index: "inputVoltage.{{ $index }}"
          low_warn_limit: inputVoltageThLowerWarning
          low_limit: inputVoltageThLowerCritical
          warn_limit: inputVoltageThUpperWarning
          high_limit: inputVoltageThUpperCritical
    #works correctly
    power:
      data:
        - oid: inputPowerTable
          value: inputWatts
          num_oid: ".1.3.6.1.4.1.534.6.6.7.3.4.1.4.{{ $index }}"
          multiplier: 1
          index: "inputWatts.{{ $index }}"
          descr: "Current Power Usage"
    #works correctly
    power_consumed:
      data:
        - oid: inputTotalPowerTable
          value: inputTotalWh
          num_oid: ".1.3.6.1.4.1.534.6.6.7.3.5.1.5.{{ $index }}"
          divisor: 1000
          index: "inputTotalWh.{{ $index }}"
          descr: "Total Wh used since reset"
    #works correctly
    power_factor:
      data:
          value: inputTotalPowerFactor
          num_oid: ".1.3.6.1.4.1.534.6.6.7.3.5.1.7.{{ $index }}"
          divisor: 1000
          index: "inputTotalPowerFactor.{{ $index }}"
          descr: "Powerfactor"
    #doesnt show up
    load:
      data:
        - oid: inputCurrentTable
          value: inputCurrentPercentLoad
          num_oid: ".1.3.6.1.4.1.534.6.6.7.3.3.1.11.{{ $index }}"
          multiplier: 1
          index: "inputCurrentPercentLoad.{{ $index }}"
          descr: "load"
    #doesnt show up
    current:
      data:
          value: inputCurrent
          num_oid: ".1.3.6.1.4.1.534.6.6.7.3.3.1.4.{{ $index}}"
          divisor: 1000
          descr: "Current"
          index: "inputCurrent.{{ $index}}"
          low_warn_limit: inputCurrentThLowerWarning
          low_limit: inputCurrentThLowerCritical
          warn_limit: inputCurrentThUpperWarning
          high_limit: inputCurrentThUpperCritical
Output of discovery module sensors:
#### Load disco module sensors ####
Caching data: os sensors
 ENTITY-SENSOR: Caching OIDs: entPhysicalDescr
Airflow:
Current: .
Charge:
Dbm:
Fanspeed:
Frequency: Cur 50, Low: null, Low Warn: null, Warn: null, High: null
Humidity:
Load:
Loss:
Power: Cur 12, Low: null, Low Warn: null, Warn: null, High: null
Power_consumed: Cur 0.302, Low: null, Low Warn: null, Warn: null, High: null
Power_factor: Cur 0.404, Low: null, Low Warn: null, Warn: null, High: null
Runtime:
Signal:
State:
Count:
Temperature:
Tv_signal:
Bitrate:
Voltage: Cur 231.51, Low: 180, Low Warn: 190, Warn: 255, High: 265
Snr:
Pressure:
Cooling:
Delay:
Quality_factor:
Chromatic_dispersion:
Ber:
Eer:
Waterflow:
Percent:
If anyone can help me out, i would really appreciate that!
