Customize Edge in Network Map?
I have an edge in a custom Network Map that goes to our ISP. The link is a 10Gbps link but the subscribed rate is only 2Gbps. While I can set it to bps, I’d like to have it show the percentage based off the 2Gbps rather than 10Gbps (I know Weathermap can do this but the “Custom Maps” in LibreNMS look better and are easier to position).
Thanks!
You can override the interface speed by using Interface Description Parsing by setting the speed to i think [2G/2G] or it might have to be [2000M/2000M] cant remember.
[ ] contains the service type or speed”
Worked like a charm. Thank you!
