i have only 1 nas asustor that i can to check status of disk
in according to official docs
i need to check
.1.3.6.1.4.1.44738.4.1.1.5.1
so i add my device
edit → customoid
NAME DISK 1 - DISK STATE
OID .1.3.6.1.4.1.44738.4.1.1.5.1
when i click TEST OID
Test successful for DISK 1 - DISK STATE, value Healthy received
so works fine. Healthy is status of disk.
so now i would crearte an alert rule when value IS NOT Healthy
so i create an alert rule with match to my device and rule
customoids.customoid_oid = “.1.3.6.1.4.1.44738.4.1.1.5.1” AND customoids.customoid_current != “test”
max alert = 1
Dealy = 1m
interval = 5m
i can’t sure that customoids.customoid_descr is NAME. so i used customoids.customoid_oid
ok but alert NOT start! in alert page i can’t find nothing… is empty…
so i can check poller and find
array (
'customoid_id' => 3,
'device_id' => 6,
'customoid_descr' => 'DISK 1 - DISK STATE',
'customoid_deleted' => 0,
'customoid_current' => 0.0,
'customoid_prev' => 0.0,
'customoid_oid' => '.1.3.6.1.4.1.44738.4.1.1.5.1',
'customoid_datatype' => '',
'customoid_unit' => '',
'customoid_divisor' => 1,
'customoid_multiplier' => 1,
'customoid_limit' => 0.0,
'customoid_limit_warn' => 0.0,
'customoid_limit_low' => 0.0,
'customoid_limit_low_warn' => 0.0,
'customoid_alert' => 0,
'customoid_passed' => 1,
'lastupdate' => '2024-06-03 13:33:49',
'user_func' => '',
SNMP['/usr/bin/snmpget' '-v2c' '-c' 'COMMUNITY' '-Oqv' '-M' '/opt/librenms/mibs' 'udp:HOSTNAME:65001' '.1.3.6.1.4.1.44738.4.1.1.5.1']
"Healthy"
Custom OID DISK 1 - DISK STATE: 0
SQL[UPDATE `customoids` set `customoid_current`=?,`lastupdate`=NOW(),`customoid_prev`=? WHERE `customoid_id` = ? [0,0,3] 0.88ms]
snmpget seems capture Healthy but in current i have 0.0
‘customoid_current’ => 0.0,
can i “write” value Healthy and check if not Healthy run an alert?
i search on forum but points all to yaml and discovery…
but for 1 value for me is better use customoid…
thank you
