@pavel.khardikov
If i am not wrong, looks like custom PHP discovery is needed for SFP/DDM …
Thanks, but I have no problem with SFP/DDM
Issue with empty processor, memory and platform and model detection.
The first three links have screenshots.
@pavel.khardikov
would you please upload snmpwalk with inserted optical SFP modules?
i started to work on this device, but i want to make it complete
yes, CPU and MEM and Model, Serial, it is working, but i need some data with SFP inserted
Peca_Nesovanovic:
Yes, now I can only with one module.
On Monday I can add more if needed.
it is OK
one is enough to see values
ok, PR based on your data
librenms:master ← Npeca75:dlink-dgs1210
opened 01:58PM - 27 Feb 22 UTC
initial support for
dgs1210-20
dgs1210-28
CPU, MEM, SFP DDM, SFP Inventory
#### Please note
> Please read this information carefully. You can run `./lnms dev:check` to check your code before submitting.
- [x] Have you followed our [code guidelines?](https://docs.librenms.org/Developing/Code-Guidelines/)
- [x] If my Pull Request does some changes/fixes/enhancements in the WebUI, I have inserted a screenshot of it.
- [x] If my Pull Request makes discovery/polling/yaml changes, I have added/updated [test data](https://docs.librenms.org/Developing/os/Test-Units/).
#### Testers
After you are done testing, you can remove the changes with `./scripts/github-remove`. If there are schema changes, you can ask on discord how to revert.
Thank you so much for helping me and for contributing to the community!
I applied the patch, it works great
Привет @pavel.khardikov
i remember when @PipoCanaja helped me few years ago with some sh*** TP-LINK
it was time to give back something to community
