j808
19 September 2019 19:25
1
[root@DIT-LibreNMS librenms]# ./validate.php ====================================
Component
Version
LibreNMS
1.52-70-gf3ba894
DB Schema
2019_05_30_225937_device_groups_rewrite (135)
PHP
7.2.22
MySQL
5.5.64-MariaDB
RRDTool
1.4.8
SNMP
NET-SNMP 5.7.2
I noticed my database has grown and not shrinking.
For some reason my ibdata1 is huge. I tried running the daily.sh and it hands on cleaning DB. It errors out after about 12 hours saying mysql error.
ibdata1 = 763.8 GiB
Refreshing device group table relationships
./daily.sh
Updating SQL-Schema OK
Cleaning up DB
I have put this in my.cnf
innodb_file_per_table=1
j808
19 September 2019 21:07
2
I was able to get it to finish running but database size did not shrink at all.
Yes mysql does not shrink files. You can dump to sql and re-import.
j808
22 September 2019 20:49
4
I reimported and found it took more space. It now gives this error
Sep 22 10:44:49 LibreNMS postfix/cleanup[679]: E633F20A12C7: message-id=20190922204449.E633F20A12C7@LibreNMS
Sep 22 10:44:49 LibreNMS postfix/cleanup[679]: warning: E633F20A12C7: write queue file: No space left on device
Sep 22 10:44:49 LibreNMS postfix/pickup[16320]: warning: maildrop/29EC320A040D: error writing E633F20A12C7: queue file write error
Sep 22 10:44:50 LibreNMS postfix/pickup[16320]: E6B1E20A12C7: uid=0 from=
Sep 22 10:44:50 LibreNMS postfix/cleanup[679]: E6B1E20A12C7: message-id=20190922204450.E6B1E20A12C7@LibreNMS
Sep 22 10:44:50 LibreNMS postfix/cleanup[679]: warning: E6B1E20A12C7: write queue file: No space left on device
Sep 22 10:44:50 LibreNMS postfix/pickup[16320]: warning: maildrop/BA46C20A12A1: error writing E6B1E20A12C7: queue file write error
Sep 22 10:44:51 LibreNMS postfix/pickup[16320]: E734A20A12E8: uid=0 from=
Sep 22 10:44:51 LibreNMS postfix/cleanup[679]: E734A20A12E8: message-id=20190922204451.E734A20A12E8@LibreNMS
Sep 22 10:44:51 LibreNMS postfix/cleanup[679]: warning: E734A20A12E8: write queue file: No space left on device
Sep 22 10:44:51 LibreNMS postfix/pickup[16320]: warning: maildrop/02C7420A126E: error writing E734A20A12E8: queue file write error
Sep 22 10:44:52 LibreNMS postfix/pickup[16320]: E7BF620A12E8: uid=0 from=
Sep 22 10:44:52 LibreNMS postfix/cleanup[679]: E7BF620A12E8: message-id=20190922204452.E7BF620A12E8@LibreNMS
Sep 22 10:44:52 LibreNMS postfix/cleanup[679]: warning: E7BF620A12E8: write queue file: No space left on device
Sep 22 10:44:52 LibreNMS postfix/pickup[16320]: warning: maildrop/B5B7D20A10DD: error writing E7BF620A12E8: queue file write error
j808
24 September 2019 22:54
5
Ok so I reimported it. It shrank by half. Do I have to keep doing this when it grows or will it start to shrink now? I noticed its not kept in ibdata1 anymore.
if you have the daily cleanup running it should keep it at a reasonable size.
That is because you set innodb_file_per_table=1
j808
26 September 2019 19:03
7
what should innodb_file_per_table=1 be set too?
Whatever you want, LibreNMS suggest it is set because it makes some management things easier, such as shrinking the db files.
