The output of ./validate.php
LibreNMS | 22.11.0-21-g47cc169f4 (2022-12-12T08:02:49+00:00)
DB Schema | 2022_09_03_091314_update_ports_adsl_table_with_defaults (248)
PHP | 8.2.0
Python | 3.9.2
Database | MariaDB 10.5.15-MariaDB-0+deb11u1
RRDTool | 1.7.2
SNMP | 5.9
[OK] Composer Version: 2.4.4
[OK]
[OK] MySQl and PHP time match
I built a new clean Debian 11 server a month ago and did a clean install
A few days ago I ran a apt update && apt upgrade and the upgrade installed PHP 8.2
Now when ./daily runs I get the following error, can anyone help me resolve the errors
[32mInstalling dependencies from lock file [39m [32mVerifying lock file contents can be installed on current platform. [39m [37;41mYour lock file does not contain a compatible set of packages. Please run composer update. [39;49m
Problem 1
- fgrosse/phpasn1 is locked to version v2.4.0 and an update of this package was not requested.
- fgrosse/phpasn1 v2.4.0 requires php ~7.1.0 || ~7.2.0 || ~7.3.0 ||
~7.4.0 || ~8.0.0 || ~8.1.0 → your php version (8.2.0) does not satisfy that requirement.
Problem 2
- web-token/jwt-core v2.2.11 requires fgrosse/phpasn1 ^2.0 → satisfiable by fgrosse/phpasn1[v2.4.0].
- web-token/jwt-core is locked to version v2.2.11 and an update of this package was not requested.
I have same problem. I run LibreNMS on debian and my php got updated from version 8.1 to version 8.2. I’ve managed to run it on 8.2 version but my daily.sh has this error.
Updating Composer packages FAIL
Problem 1
- fgrosse/phpasn1 v2.4.0 requires php ~7.1.0 || ~7.2.0 || ~7.3.0 || ~7.4.0 || ~8.0.0 || ~8.1.0 → your php version (8.2.0) does not satisfy that requirement.
Problem 2
Ran the above commands and my install cannot find “composer” so I ran
./scripts/composer_wrapper.php update then ./daily and I still get the same error with (even tried * ./scripts/composer_wrapper.php install --no-dev but till the same - below error wth running ./daily.sh)
Problem 1
Problem 2
Forcing a composer update won’t fix anything, it just ignores the problem.
The problem is the composer.lock file needs to be updated on Git to reflect the PHP 8.2 update (package fgrosse/phpasn1 – line 1281). The devs are now aware of the issue, so expect a fix coming within the next few days. I wouldn’t worry about it at all until then.
I’d say if your installation is working fine on 8.2 (just failing auto-updates), you are good to go. If you’re just installing LibreNMS today on Debian 11, things could get sticky, and a composer force update would be warranted.
